brake help
(In Topic #152194)
mk2 16v servo, new g60 front brakes, mk4 rear brakes, new lines, new m/c …
the problem im having is when the engine is NOT running the brake feel good and solid after a couple of pups of the pedal
however when i start the engine i can put the pedal down until it hits the floor
the vacuum seem to be ok and i have adjusted the brake rods
the only thing i havent played with is the adjustment on the rod back of the servo, can this affect the vacuum ???…????…..
Are the bleed nipples at the top of the calipers on the rears?
cheers mate
