Bit of a result !! G60 brakes
(In Topic #115776)
just got back from my local scrap yard where he has a G60 Corrado with engine and all running gear in place.
Just paid ?180 for Front and Rear discs calipers carriers hubs master cylinder and servo. Good Deal?
What do i need to fit this little lot to my Sportline?
He still has the engine in its complete state he wants ?450 for it the car has 105k on the clock.
will get the phone number tomorrow if anyone is interested in the engine and box?
hi i got all the same bits for my tin top gti
the back brakes was easy as the stub axles bolt straight onto rear beem
i bought new splash guards from vw they wer not too pricey
you need handbrake cables for 16v scirocco i may have part no if you need it
the front has been more complicated tho
i decided to use the whole front hub assembly from the corrado as the caliper carriers etc fit it
however the hub carrier is thicker and the bolt holes dont take mk1 suspension
i had this machined down so it would fit mk1 suspension and altered the position of the bolt hole also
i also fitted mk3 bottom ball joints into mk1 wishbones (slight mods req)
i have yet to complete this
the other issue is that the point where the track rod end goes in is positioned differently on mk1 but i rekon i can get around this as the car is lowered and think mk2 track rod ends will help
if anyone else has done this i would also like advise
also if anyone can tell me if any of above is incorrect please let me know
Stu
Stu
where abouts was engine based mate
<a><img></a>
sounds like a lot of grief on the front brakes.
i think i have seen something on hear about G60 brakes and they used an adapter plate / bracket to take calipers on mk1 hubs.
part number for 16v Scirroco cables would be great
Engine is based in birmingham
miles away from me wanted the engine
<a><img></a>
Ive got a pair of Scirroco 16v handbrake cables brand new in bags if interested. bought them with the intention of doing a rear disk conversion which never happenend
pm me if your interested
Do you REALLY need rear discs ?
There i a reason why most of the top tuning companies stopped selling rear disc conversions for the mk1 !!!!!
I run a G60 mk1 with about 185 BHP with standard rear drums.
You only really need the fronts being a little bigger and the MK2 golf servo and master cylinder would be your best modification.
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2019 Skoda Octavia Sport ( it’s Golf)
hello chink sent u a pm
<a><img></a>
part number
Hi part number for handbrake cables is
533609721 ?13.80 each
Stu
Stu
Thanks all
having a mare fitting these G60s got the suggested plates off ebay but cant figure out which way round they fit to take the G60 280mm discs either way i try something clashes any pics or links anywhere??
i have got the corrado hubs but it seems like a lot of work to get these to fit to a mk1. am i right?
the car has got 250 mm discs and girling 54 callipers fitted already are these an upgrade ?if so should i just call it a day?
got the rears all sorted bar the jump hoses and hand brake cables
Thanks for the part number
239 are standard and 256 would be an upgrade!! Which mounts did you get for the brakes as i was just about to buy some??
And for the disc thing, must just be for cosmetic reasons as there won't be that much difference, is there?? I want it just cause they look good and due to the fact i hate working on drums
MK1 16v on twin 40's + my name's Stewart
yep i hate drums tooo so much
copy bellow into Ebay search and there what ive got
Mk1 golf Conversion Kit for G60/280mm.Caliper Brackets
just cant see how they will allow me to fit 280mm discs and g60 calipers what ever i try either carrier, bracket or disc clash!
g60 conversion problem
im half way through doing a mk1 g60 conversion ,
iv got the whole front end of a g60 corrado, discs, callipers, hubs, hub carrier (frame) engine ecttt…
i have came across a problem though got all the front end fitted but mk1 golf coilovers doesent slot into the g60 hub carriers
does this mean i have to buy 2 sets of coilovers mk1 golf for the back and g60 for the front ?
or am i right buy saying a mk2 golf coilovers set would do the job
helpppppp !!!
LOL by fitting the corrado hubs you will screw up your geometry.
Chink, you bolt the adaptor to the hub then the caliper to the adaptor, simples. you will prob want to do a 9" servo and 22mm m/c to go with them.
@ Funkstar, you have PM mate.
I heard that fitting mk2 16 valve hubs will work with g60 brakes. But as said it messes geometry. You have to get extensions of some sort for the bottom ball joint and the track rod has to be raised to eliminate bump steer.
How are 256s meant to be fitted?
mk1/mk2 8v golf hubs are the same so only 239s can be fitted. Whats different to fit 256s?
Saab 93 diesel daily
