Best place to get a carb?
(In Topic #124705)
Along the same lines, what options are there for exhausts?
2008 Citro'n C6 (C6 RTK)
1993 Jeep Cherokee. 1985 Scimitar SS1
132 cars in 18 years…
Past VWs: Mk 1 Clipper, Mk 2 Polo, Beetles, Beetle Cab, Buses, Passats, Sciroccos, Golf Mk 2 GTis, Jetta Syncro, New Beetle Cabrio
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
I've seen NOS Pierburgs on eBay, but have to get the right one - last one was for an Audi 80.
How much of the vacuum piping disappears with a Weber? Do I lose the green reservoir and so forth? I know I lose the autochoke so have to bypass that bit of the cooling system.
As for what you lose, all the pipes on the carb, the green ball, some of the water pipes. You gain a few bhp from a webber aswell
I'm thinking:
Weber and a chrome pancake-style open air filter. Is there a suitable kit for that, losing the black VW airbox and so forth? Manual choke is presumably dead simple and fits into the blank space in the dash without any mangling needed?
Also, does a weber carb then mean that a GTi silicon hose set would fit straight in?
Setup is the other question. I'm assuming it'd run out of the box, but need tuning to get it all adjusted correctly?
Then I just need suitable downpipes and exhaust system to get rid of the blowing joints and make it sound appropriately nice…
Does anything odd need doing with the wiring?
there is a weber conversion fron crazyquiffs, or fast road cars. also think funkstar can get them
the manual choke version will cost you around £230 ish
with the kit come all the pipe and choke cable so it will just simply swop over.
a pancake filter will cost you around £60 ish and the brake come with the kit to attach it
they say they do come set up out the box but mine was running rich but still ran fine, if you take it to a garage they won't charge alot to set it up as they are so easy to do so
the silicone hose kit will do you coolent hose so this wont interfer with the carb at all and i think you can get a carb kit reather than a gti
hth
Or I got one from Aldon Automotive for less than that assming it's the same style…
My Bible
(never got round to fitting mine yet though)
If that'll make my Golf sound better, not cut out when cold, and generally not make a sound like a kazoo (a sound like a purposeful sporty engine is fine) then that's what I need.
My old Mk 1 Escort 1300 Sport had one of those and a twin-choke weber. Sounded awesome, you could hear it so well through the holes in the floor
