Best place for axle stands
(In Topic #148351)
been doing searches for this but there are a lot of mixed opinions so any advice on the best/strongest places to jack and
place axle stands under would be very helpful.
'83 formel e
And yeah was thinking of using some wood as that's what i've used before on the rear beam for the axle stands but a rubber mat is a much better idea, bit softer for the old girl
'83 formel e
Mrs Choc Rolls Stock!
ned_h said
do you mean at the rear wishbone mount and directly under it or beside it?
No, I mean the front wishbone mount. It's more structural than the rear wishbone mount. So jack it up on the circular pressing just inset of the sill at the front of the floorpan, and put axle stands under the front wishbone mounts. Thats how I do it every time now
Just found this pic from an old thread;
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=88089
On the rear, I always jack it up under the rear beam and put the stands under the beam also, but if the beam isn't fitted or needs to be removed then I would use the jack in the middle of the beam, then the stands can go under either the back of the sills where the rear most part of the floor meets it (I.e. on the sill just in front of the rear beam mounts). Or, there are little pressed sections of metal protruding downwards just inset of the rear panel on either side, welded underneath the chassis rails. They are easy to spot as they have a circular cutout facing down.
View from underneath;
You could put the stands here or you could jack it up here. You'll find your own method Obviously make sure wherever you jack it it isn't so rusty that it's going to collapse through.
I hate supporting the shell on the sill folds but when I absolutely have to I made these little notched peices of wood to sit the fold into so that it doesn't bend. Should support it the same way a widowmaker jack would but without damaging the metal.
for the rear i'll place them under the beam again as im not removing it
but yeah thanks a lot for that, i'll give that ago
'83 formel e
Don't support the car on the rear axle.
I personally use the piece right at the back of the chassis rails at the rear, or if it needs to go higher the place on the sill as above.
<a href="http://s398.photobucket.com/albums/pp63/JoeMk1/?action=view?t=sig3.jpg"><img src="http://i398.photobucket.com/albums/pp63/JoeMk1/sig3.jpg" border="0" alt="Photobucket"></a>
