Advice on buying a mk 1 clipper cabriolet.
(In Topic #89407)
Tomorrow I am going to look and hopefully buy my first mark 1 cabriolet. It is 1991 and looks well in pictures.
Is there any recurring problems that I should look out for.
I think this one has electric roof, would that be possible in these models.
Any advice would be welcomed and as usual I have left this till the last minute..
Also am a bit confursed about the difference between a clipper and a karman cabriolet or is there no difference.
Thanks Seanie
Seanie,
'Better to wear out than rust out'
Web Team
Have a read of our buyers guide……
http://www.vwgolfmk1.info/main/Buyingacab.pdf
It it possible it may have a electric roof. Karmann applies to all models - manufacturers name. Clipper is a model of cab.
Let us know how you get on…..
The car ain't new, and as such, it's heavy and solid, don't be surprised if the doors dip slightly when you open it, but any more than a centimetre and it's gonna need fixed.
take it a nice long drive, dealing with top gear cruising and driving slowly and stopping regularly, in a built up area, be wary of stuttering and the car wanting to die…hopefully it won't.
OPEN THE FUEL CAP AND CHECK THE FILLER NECK!! If you see rust, and holes….It's gonna cost you ?60 and a mechanics time and pay(if you can't do it yourself) to fix this, and if you don't, you get problems.
Check under the arches for rust, and in the boot under the spare wheel.
The brakes will be bad, if they feel a mile away, get used to it
check all your switches do what they should.
At the end of the day mate, you'll know if it feels right or wrong to part with your cash for the car, and if it's the latter, walk away. The right one will be out there for you.
All the best of luck, and I look forward to a successful view and buy story and some nice pics of your new cab.
Cheers,
Tony.
Cabs Rule!
'83 Black GTI Cab on BBS RAs - DreamBoat 3000'
Resto = http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=67552
Seanie,
one things for sure mate, if it's the one for you, and you get to drive it home, you will fall in love all the way home and will have loved the decision.
I'll be thinking of you tomorrow at work :pray:
Tony.
check the clutch mate (give it a bit of welly in low gears if revs fly up and u aint moving tis a bad sign (but not end of world, new clutch)). stick it in 2nd gear and slowly release clutch also if engine spins up then a new clutch.
check behind clipper kit for rust.
get the engine warm these take an era.. if they do get warm fast summats wrong. bullet proof engines let down by a poo carb, when they are running right indestructable.
check cracked springs, front wheel bearings, grumblings from bottom end, check exhaust fumes when warm if theres smoke of any colour summats up.
good luck mate,
paul
really sure which one of us is more excited.
However when it comes to the decision, I have made my mind up if the
car is not for me, I will wait for the right one.
One thing for sure, I'll be back to tell you all , how things went.
Seanie,
Regards
dibbler
car would not be as good as it looked in pictures. Thankfully it was just
as good. Bought it at 3 pm yesterday and now having driven 420 miles
260 in England and 160 here , I feel the car has survived a major early test.
There are one or two small things, (one of which was highlighted by one of your members) that is a little rust in the filler pipe for the petrol. So that needs to be looked at. I will get the photos and introduce me and the car to the club later.
Delighted with the car , as is my 9 year old who accompanied my on this
epic trip.
Seanie,
Well done mate, hopefully you will have a long and happy mk1 ownership.
Looking forward to see those pics.
Tones.
(fellow new happy cabby owner!)
rebuild in progress....
Would appreciate any advice if someone's had this problem.
Seanie,
The Mk1 Golf Owners Club
this is NOT the correct way to do it according to most people but hell it worked for me
replacing filler neck is easy enough, take off old one fit new!
