1.8 engine pick-up-able?
(In Topic #89822)
i`m picking a 1.8 gti engine and gearbox on saturday. will i be able to lift it into the back of my car with the help of a friend or will i need to take an engine crane?
cheers in advance…andy
sharp customs bodyshop, mansfield, notts
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=99756
Two of you should manage it ok
Depends what's still attached. I'd say with the exhaust and inlet manifold, its a definite 3 person, rather than 2 person, lift. Maybe with the manifolds off, 2 people could do it. Bit awkward to find something to grip onto though. Also, depends what kind of car you're lifting it into! You'll struggle to use a crane to get it into the Mk1 hatchback, since the job of the crane will hit the rear glass.
Best to separate engine + gearbox and then two can easily (?) manage the engine and one can do the gearbox. It's only a few bolts - five min job when they're out of the car and accessible
I'm with oldfart, best remove gearbox - not just weight, but will also be harder to fit into car as one. Got 1.6 GTI engine into boot of my mk2 and out with a mate without to much difficulty. Gearboxes don't weigh too much at all, easy to lift by yourself. I built up the boot floor height with some roof bars and bits of wood so that we didn't have to lift the engine over the boot opening.
1983 1100 C
1983 1100 C
Picked up a DX engine the other week, was ok to lift with 2 of you, but then when I came to move it again with my other weaker mate he could'nt hold it and dropped it!!!! what a dougnut!!!
So make sure your mate is a beefcake
1983 MK1 PIRELLI EDITION
Alpine White LHD ("SOLD")
make sure you drain the oil so you can lay the motor down 8)
a mate didnt his back window is now clingfilm :mrgreen: :wink:
mobile welder wirral here
http://www.volkszone.com/VZi/showthread.php?t=366253
all good points, i`m goin in a citroen xantia so it should`t be a problem with clearance for an engine crane, i just can`t be bothered to take one.. they`re really heavy!
i`ll chance it i reckon… cheers.
if u cant lift one of these you are in a bad way.....
noted tomo. if i break my back then i`ll be sure to post up my x-rays for all to see.
drop the oil and coolant out of the engine mate, try and get someone else to give you a lift, sorry i was drunk when i wrote that. its easier if you can get a strong beam and some rope and do it that way as your back doesnt take all the strain. use your knees!
