Tin top boot lock
Just wondering as I've read a couple of conflicting bits of info
Is it possible to re-ky a boot lock? I know for the door locks you remove the pins and replace so the key works. Is the boot the same?
If so how the hell do you get to the pins?
ta
Ian
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
You can do it, I did mine recently.
Remove the lock from the boot by removing the 3 latch screws.
Then, If you push in the chrome button, it will expose a small roll pin at the other end of the lock. Knock the pin out and then the lock cylinder will pull out from the front.
After this you change the brass pins as per the door locks, then rebuild in reverse of disassembly.
Thanks mate, I'd got as far as the disassmbly with no issues but I didn't think I could see the pins. I'll have another look.
Ian
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
some call them wafers, there is a small spring that is on them
They are the little things sticking out covered in grease, but you can also see them at the bottom.
Yup all sorted.
I just needed to hut it a bit harder to get the barrel out of the lock surround.
Ta chaps
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
do you need the key in when taking out the barrel?
Nope. Just tap it a bit harder with a hammer and drift  ;)
If it worked ion a key I wouldn't need to remove it!
Ian
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
I have had it go both ways, some I have fixed I did have to have the key in, and some came out easily without.
hello all,
nice place to be here, i see nice comments and nice people as well, i will make it a point to come here more often to read and post comments so people and myself benefit.
Cheers!!!
Download Toy Blast 1.0
thanks turns out it was just seized up and had the right key for it anyway. on a different topic has anyone seen a tintop with a boot light? got this latch mech with a switch on, never seen another like it, citi golf maybe?
Interesting.
I've run a light switch pick up on mine, used a Toyota boot pick for it.
I like the idea of it being in the catch!
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
Brilliant, so helpful just matched both door locks and the boot lock to the ignition barrel. Thanks a million for sharing!
 Black 1984 MK1 Golf GTI Campaign.
 thanks so much, I'd been foxed by that pesky pin for a while!
My rear boot didn't have a boot light, so I made one that fit under the Parcel shelf.  It came with a rocker switch.
Pulled the Carpet off, drilled a couple of holes, replace the carpet…. I used it alot as it was a work car, and in the middle of the night, looking for parts it was a godsend.
Eventually Put one on each side of the Parcel shelf.
I found this guide from a scirocco site very useful: http://sciroccoregister.co.uk/carforum/viewtopic.php?t=55
It shows in detail how to remove the wafers of the door lock and the lock barrel from the boot lock
Early 77 year model Golf. 4-Door
