My DIY list of things for a 90ish Cabriolet (digifant2) part 1
(In Topic #208410)
Finally found the place where I should add all my how do I do that's. So here are all my how-tos by category, remember, they are 1990 Cabriolet for most of them, but the suspension / engine / body/interior all apply to the MK1 Generally.
Have fun,,,,,,,
Here are all my how-tos by category, remember, they are 1990 Cabriolet for most of them but they all apply to the MK1 Generally.
FIRST TIME POSTERS READ
HOW to ask for HELP.
Convertible Top
Cheaper Rear Cable (cost effective)
http://volkswagenowner…/99266-Cheaper-Rear-Cable.
Top frame Seals:
http://volkswagenowner…Seals?p=605050#post605050
Replacing your Top, that pesky rear cable.
http://volkswagenowner…able.?p=638234#post638234
Top Boot Cover Strap Upgrade.
http://www.toplessrabb…viewtopic.php?f=41&t=3271
Rear Cable that I can endorse.
http://www.toplessrabb…viewtopic.php?f=41&t=3012
Rear Cable Lubricant for Cloth tops.
http://www.toplessrabb…viewtopic.php?f=41&t=3208
How I install convertible tops.
http://volkswagenowner…vertible-Top-Installation
Installing your top padding kit.
http://volkswagenowner…olet-Top-Pad-Installation
Installing your head liner.
http://www.toplessrabb…viewtopic.php?f=41&t=3013
Replacing your rear window.
http://volkswagenowner…ment.?p=519466#post519466
How to make your own rain gutters.
http://volkswagenowner…our-own-Vert-rain-gutters
"A" pillar gap repair.
http://volkswagenowner…uot-pillar-repair-the-Gap.
Wind Noise at the leading edge.
http://volkswagenowner…-top.?p=655074#post655074
How to clean your "A" pillar seal.
http://volkswagenowner…r-quot-A-quot-pillar-Seal
Cabriolet top pad measurements.
http://volkswagenowner…olet-Top-Pad-Measurements
Ez-on top replacement instructions.
http://volkswagenowner…abriolet-Top-Installation
"A" pillar door seal repair, stop the drip.
http://volkswagenowner…t-A-quot-Pillar-Door-Seal
Where to oil your top frame.
http://volkswagenowner…olet-Top-Frame-Oil-Points
Cheaper replacement top struts.
http://volkswagenowner…er-Top-Strut-Replacements
Top latch removal
http://volkswagenowner…briolet-Top-Latch-removal
Make your own rear cable.
http://volkswagenowner…-Cabriolet-DIY-rear-cable
Improve and make your own side tension cables.
http://volkswagenowner…t-DIY-side-tension-cables
Brake Reference Pictures.
http://volkswagenowner…ures.?p=655466#post655466
Have fun,,,,,,,
Convertible Top
Top frame Seals:
Top latch removal
Wow Brian by the time I get past part 1 I'll be past!
But the car will be perfect!
Electrical/Educational
Educational:
Inside of a fuse box
http://forums.vwvortexâ(EUR-)¦er-Look-inside-a-fuse-box
Definitive Radiator fan operation explained:
http://volkswagenownerâ(EUR-)¦-Fan-operation-explained-
Basic Electrical Tools for most common Repairs/Diagnosis.
http://www.toplessrabbâ(EUR-)¦/viewtopic.php?f=7&t=3211
Briano's quick ground test
Briano's Quick Grounds test. | Volkswagen Owners Club Forum
Improving your grounds 93 digi.
http://forums.vwvortexâ(EUR-)¦nd-the-repair-of-your-car
Improving your cluster grounds.
http://volkswagenownerâ(EUR-)¦er-Connections-and-ground.
Electrical Primer
http://volkswagenownerâ(EUR-)¦php/32254-Electric-Primer
Parasitic Drain Video
http://volkswagenownerâ(EUR-)¦228-Parasitic-Drain-Video
Electrical:
Intermittently Honking Horn on turns.
Intermittent Horn Honking on turns and Bumps? - Topless Rabbit Forums
How I splice in wires.
http://www.toplessrabbit.com/forums/viewtopic.php?f=7&t=3524
A/C blower motor replacement tips.
A/C Blower Motor Replacement tips. | Volkswagen Owners Club Forum
Alternator Tune up:
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Falternator-tune-up&redirected=1#post_1592287
Repairing your Fuel Sending unit.
http://volkswagenownerâ(EUR-)¦-Unit?p=600458#post600458
Headlight/Marker light out with Key out.
http://forums.vwvortexâ(EUR-)¦ghts-off-with-Key-out-fix
Repairing Mylar runs to the 10V Stabilizer. (Or Backfeeding the Voltages to the gauges.
http://volkswagenownerâ(EUR-)¦izer.?p=531266#post531266
Replacing the Ignition Switch in 90is Cabriolets.
http://volkswagenownerâ(EUR-)¦olet.?p=588594#post588594
How to remove your automatic starter.
http://volkswagenownerâ(EUR-)¦c-Starter-Removal-Install
My Wipers work, but the washer don't.
http://volkswagenownerâ(EUR-)¦ork-but-the-Washers-don-t.
Relaying your headlights.
http://volkswagenownerâ(EUR-)¦Relaying-your-Head-Lights
Installing a a/c cut-out switch.
http://volkswagenownerâ(EUR-)¦compressor-Cut-out-Switch
Removing your non-york Alternator
http://volkswagenownerâ(EUR-)¦ator-Removal-Non-York-A-C
Cabriolet Bulb replacement numbers
http://volkswagenownerâ(EUR-)¦-Bulb-Replacement-numbers
1985-1993 Radio Wiring pairs
http://volkswagenownerâ(EUR-)¦riolet-Radio-Wiring-Pairs.
1990-1993 Automatic no crank warm or cold
http://volkswagenownerâ(EUR-)¦atic-No-Crank-Hot-or-Cold
1990-1993 Testing your Water temp gauge
http://volkswagenownerâ(EUR-)¦ting-Digifant-Water-Gauge
Repairing your flaky water temp gauge.
http://volkswagenownerâ(EUR-)¦ur-Flaky-Water-Temp-Gauge
The smarter fuse:
http://volkswagenownerâ(EUR-)¦Fuses...-Glows-when-blows.
Repair your rear window defroster lines:
http://toplessrabbit.câ(EUR-)¦php?mode=edit&f=7&p=17634
Okay here is the link that I was referring to for some reason I can't reply to your private post, and well sometimes I forget to post new onew to augment my how-to's I blame my Oldtimers Disease, or CRS Can't Remember Spit* *(insert the proper evacuated waste word of your choosing).
My Cigarette Lighter won't charge my ipad.
My Cigarette lighter won't charge my Ipad, Iphone. | Volkswagen Owners Club Forum
Educational:
Electrical Primer
Electrical:
Alternator Tune up:
The smarter fuse:
Last edit: by Briano1234
Engine/cooling:
Radiator return upgrade.
http://volkswagenowner…rade.?p=663858#post663858
Leaky Heater Valve, and beefing it up.
http://volkswagenowner….....?p=644178#post644178
Swapping in a 2.0L 36mm Oil pump. Heads up.http://www.toplessrabb…/viewtopic.php?f=6&t=3232
How I hate plastic parts:
http://forums.vwvortex…hlight=hate+plastic+parts
How I converted from r12 with r134a:
http://volkswagenowner…converted-my-a-c-to-r134a
Definitive Radiator Fan Circuits explained:
http://volkswagenowner…ned-)?p=504978#post504978
How to flush your radiator:
http://volkswagenowner…ow-to-flush-your-radiator
How to replace your Valve cover gasket 1990-1993
http://volkswagenowner…Cover-Gasket.-90-93-Cabby.
How to change your water pump 1990-1993 Cabriolet
http://volkswagenowner…-change-out-my-Water-Pump
How to tighten a squealing a/c belt.
http://volkswagenowner…ighten-Squeeling-a-c-Belt
Triming your Radiator Shroud easy on/off.
http://volkswagenowner…ming-your-Radiator-Shroud
How to change your in-tank fuel pump 1984.5-1993.
http://volkswagenowner…ge-your-in-tank-fuel-pump
Additions to Ron's Digifant Single Fuel Pump Conversion.
http://forums.vwvortex…ht=big+thank+you+Tolusina
How I change the plug wires.
http://volkswagenowner…-Plugs-and-Wires-Digifant.
How to install a external oil cooler.
http://volkswagenowner…ng-an-External-Oil-Cooler
Digifant Intake tube repair.
http://volkswagenowner…nt-Air-Intake-Tube-Repair
Create your own dual down pipe:
http://volkswagenowner…ur-own-dual-down-pipe-1.8
Exterior:
Leaky Car Syndrome fixes:
Another Leaky Knee Fix.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=2737
Swimming Pool in Front Seats.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=2853
Where is my top leaking.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=2655
Where is my trunk leaking.
http://volkswagenownersclub.com/vw/showthread.php/32207-Cabriolet-mk1-Where-is-my-Trunk-Leaking
How to un-bolt pivot windows hardware.
http://forums.vwvortex.com/showthread.php?7199576-Vent-window-latch-swap&p=87874731#post87874731
Where Do I Place Jack Stands
http://forums.vwvortex.com/showthread.php?7122160-Jack-Stands-under-Cabriolet&p=87189221#post87189221
How I clean my Cabriolet.
http://volkswagenownersclub.com/vw/showthread.php/10022-How-I-clean-my-Mk1
Door Check repair from a great UK forum……..
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2F-83-gti-set-to-get-full&start=540#post_1354305
Removing your Flag Mirror Glass
http://forums.vwvortex.com/showthread.php?7068757-Ever-want-to-take-the-mirror-glass-out-of-your-flag-mirror&p=86622489#post86622489
Repair your broken Grill Tabs
http://forums.vwvortex.com/showthread.php?6981782-Broken-Grill-Tabs
Installing Front windshield videos
http://volkswagenownersclub.com/vw/showthread.php/32710-Installing-MK1-Windshield-Videos
Saggy door fix.
http://volkswagenownersclub.com/vw/showthread.php/32222-Saggy-Door-Fix
Hood Vent Debris Guard, Let's keep those rain drains clean.
http://www.toplessrabbit.com/forums/viewtopic.php?f=27&t=1509&p=27750#p27750
Factory Paint in a rattle can
http://volkswagenownersclub.com/vw/showthread.php/32221-Factory-paint-in-a-Rattle-Can.
Repair a broken grille mount.
http://volkswagenownersclub.com/vw/showthread.php/32223-How-to-repair-a-broken-Grille-mount.
Using a non-powered door in a 1990-1993 Cabriolet
http://volkswagenownersclub.com/vw/showthread.php/32199-How-to-use-a-non-Powered-window-door-in-a-later-Cabriolet
How to make a debris guard for the hood.
http://volkswagenownersclub.com/vw/showthread.php/32217-How-to-make-a-Hood-Debris-Guard
How to remove and regrease your door latches.
http://volkswagenownersclub.com/vw/showthread.php/32216-How-to-remove-and-re-grease-your-Door-Latches
How to gold leaf your badges.
http://volkswagenownersclub.com/vw/showthread.php/32198-Gold-Leafing-your-Badges
How to remove your inner lights on a quad grille:
http://volkswagenownersclub.com/vw/showthread.php/32186-Cabriolet-or-Quad-Grille-Hi-Beam-Removal
How to install your new Outer Scraper Kit on a Cabriolet.
Installing your new outer Scrapers Kit? | Volkswagen Owners Club Forum
Saggy door fix.
Is there a doctor in the house?
Interior:
Every Vent fix I have ever thought of.
http://volkswagenowner…Hands%5C-Whistleing-Vents
Cold hand whistling vents.
Rear seat back pull replacement.
http://volkswagenowner…-Release-Pull-Replacement.
Repairing your Seat bottom Bolster foam.
http://volkswagenowner…foam.?p=662258#post662258
Removing your Head rest to remove or replace the cover.
http://volkswagenowner…er-it?p=662274#post662274
Removing your Seat Back cover to repair the Bolster.
http://volkswagenowner…ters.?p=662282#post662282
My B-Pillars are dull.
http://volkswagenowner…llars-look-dull-and-dingy.
Making a Parcel Shelf.
http://volkswagenowner…ur-Cabriolet-Parcel-Shelf.
Cabriolet Trunk Lid Key Lock cover.
http://www.toplessrabb…=29&t=3198&p=27535#p27535
How to remove a door card and adjust the window and stop.
http://volkswagenowner…rd-and-adjust-window-stop
How to repair broken trunk card board.
http://volkswagenowner…et-Repair-Trunk-Cardboard.
Where is my trunk leaking:
http://volkswagenowner…Where-is-my-Trunk-Leaking
2-door/Cabriolet seat back release cable repair.
http://volkswagenowner…at-Back-Cable-Replacement
Floppy vent fix.
http://volkswagenowner…ow-to-repair-floppy-vents
Repair your Heater control pivot.
http://volkswagenowner…vot-broke-%28Cabriolet%29
A/C thermoswitch Slider pops out of the Arm.
http://volkswagenowner…lace.?p=584825#post584825
Repair a broken heater control mount.
http://volkswagenowner…-control-mount.-Cabriolet
Replace your chewed roll bar foam
http://volkswagenowner…your-Chewed-Roll-Bar-Foam
Seat rocks and is hard to slide.
http://volkswagenowner…t-rocks-and-hard-to-slide
Cabriolet Fascia mounts broke?
http://volkswagenowner…-Fascia-Mount-hole-repair
How to safely remove your center and side vents.
http://volkswagenowner…Caddy-Center-Vent-Removal
How to replace your slow seat belt retractors.
http://volkswagenowner…w-Seat-Belts-in-Cabriolet
How to remove your Hood Hinges.
http://volkswagenowner…Installing-Replacing-Hood
Floppy vent fix.
Suspension/Steering:
Broken sway bar strap fix.
http://forums.vwvortex…trap-%28cabriolets%29-fix
How to replace your rear struts:
http://volkswagenowner…-replace-your-Rear-Struts
How to replace bushings with no press.
http://volkswagenowner…-Bushings-without-a-Press.
Beefing up your Strut Mounts.
http://volkswagenowner…eefing-up-the-Strut-mount.
How to replace your front struts, and mounts.
http://volkswagenowner…g-Front-Struts-and-Mounts
How to keep the rear lower shock bolt from seizing.
http://volkswagenowner…r-Strut-Bolt-from-Seizing.
How to remove a power steering pump.
http://volkswagenowner…a-Mk1-Power-Steering-Pump
Transmission:
How to remove and replace a torque convertor seal.
http://volkswagenowner…tor-Seal-010-transmission.
How to change a differential seal:
http://volkswagenowner…nging-a-Differential-Seal
How to make a cheap weighted shift rod.
http://volkswagenowner…heap-Weighted-Shifter-Rod
Automatic Transmisison Service guide.
http://reflectionsands…s.com/a1-tech/BIGATSG.pdf
Transmission:
I would of posted in one document but it seems there is a limit to the length of post, so I had to break it up a wee bit into sections, and you got in the middle of it.Golf Cabrio said
Wow Brian by the time I get past part 1 I'll be past! But the car will be perfect!
I had that same issue on length when posting some of my longer threads, and the gracious admins gave me a length of post pass….
We've got good guys both on the back and front end of this club as you know and you're a very welcome addition for sure!
Awesome. Thanks
Brian this is awesome
My mechanic has just cancelled his holiday for next year and I have let the Mrs put the heating on for an hour!!
Wes
Wes
If any of the links are broken or hesitate, here is another link to the list, and I know all of those work.
http://volkswagenownersclub.com/vw/showthread.php/80146-Briano-s-Links-by-class...
