mk1 How to fix top armrest clip
(In Topic #199443)
DIY of how to fix upper armrest mount
I was recently looking around for new clips for the upper part of my armrests, turns out they stopped making the clips and you can no longer get them, so i decided to make my own and since i couldn't find any DIYs i decided to make one.
first off I removed the door panel
I then found a washer to use that would act as my original clip, which is a 5mmx20mm washer
I then drilled a notch in the washer so that the door handle fit and would lock when rotated
I then tack welded my washer in place, used a grinder on it, and painted it (i suck at welding), not my armrest is as good as new and stronger!
http://www.werk34.de/product_info.php/info/p14659_Clip-for-armrest--fit-for-Golf-MK1---Cabrio.html t http://www.werk34.de/product_info.php/info/p14659_Clip-for-armrest--fit-for-Golf-MK1---Cabrio.html think maybe this is the clip you was looking for? If not please delete…
On the drive
Myvalver 89 GTi Grey mk2 16v
