How to repair your grill trim (the ghetto way)
(In Topic #158996)
Marketing Manager
You will need
- A 7mm Allen key (socket one won't work as you'll need the perpendicular handle, if you have a 7mm square block this would be perfect but not everyone will have one!
- Your choice of smacking implement, a small panel beating hammer is ideal, a 24oz sledge hammer is not.
- Small flat head screwdriver
- flat solid surface
Right, so using your small flat head screwdriver slowly and carefully bend out the tabs holding the trim pieces in position. DO NOT rest the screwdriver on the grill and then try and lever the tab out as you'll probably end up snapping the plastic. Once the tabs are all bent, carefully remove the grill trim, trying to yank it out will probably result in a bent piece of aluminium that'll be about as useful as Anne Frank's drum kit.
Now you have your trim out in one piece, place it face down on your work surface
You can't really see in this picture but the trim piece has kinked out aswell as bent a bit. Time to bust out the allen key.
Place it just behind the damaged area ( make sure the perpendicular piece of the allen key is poiting directly upwards!)and gently hammer it in, if the area behind is straight, the allen key should just push in.
Using your hammer, hit your allen key on the perpendicular section (that's the sticky out bit) until it has gone all the way through the damaged area.
Now, flip the trim piece onto it's side and again using your hammer, gently tap the trim where the allen key is placed, once that side is flat, flip the piece over and repeat
Remove the allen key and voila, not perfectly straight but once fitted to the grill it will be fine. Shouldn't take you more than a minute or two!
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
Nice one Ahmet
Brill idea and that the 7mm key fits neatly into the channel…
Have you not got allen keys then?smudger said
You keeping it Ahmet or selling it on??
Got 3 grills to choose from mate I'm greedy like that
Marketing Manager
Yeah next time that's what i'll be doing chortle!
Smudge, i'm keeping this one dude, prefer it to my quad light grill!
'83 formel e
