Won't go in gears
(In Topic #232281)
If you have plenty of clear room in front of the car, start it up and warm up the engine. Turn it off and place in 2nd gear. Make sure no one is front of the car and you have plenty of room to launch into, restart the car. With a bang the clutch should free itself.
Won't go in gears
Sent from my AC2003 using Tapatalk
Won't go in gears
There is a way to 'free' the clutch if its stuck, I can't remember the details but it involves being a bit brutal with it in gear and towing it, or something like that. I could probably find an old video of a tractor clutch stuck, and freed, this way.
Won't go in gears
Are you sure it won't go into any gear at all with the engine off? Your description of grinding noises sounds like it was trying to but with the clutch still engaged becasue it was stuck on.Greenmk1 said
Hi no it doesn't go into gears whilst engine is off
Without the synchro working due to the engine being off it will be awkard to get some of the gears but you should be able to select most with a little effort.
If the clutch is rusted on the only way to fix it is to break it free by warming the engine and then restarting in gear or as Paul says bump starting it in gear, but both depend on you 1st being able to get it in gear with the engine off.
The only other way is to remove the gearbox and clutch
The fact that you can grind the gears with the engine running suggests that your clutch is stuck.
Weird??? It's either one or the other usually?????
If you suspect the linkage then it can be put into gear by manually operating the linkage, disconnecting the linkage bits to the gearstick if necessary.
And its always possible there is an internal problem, eg a piece of selector fork or a tooth or two has come off within the gearbox. Sometimes the gearbox survives because it goes into a corner or is caught on a magnet(ic drain plug), sometimes it jams certain things or everything.
