Wishbone Replacement
(In Topic #236051)
Would anyone be able to advise what's required to replace the n/a wishbone on a clipper auto?
The o/s looks straight forward but the n/s bolt looks like it can't be removed easily as it will hit the auto box?
Help much appreciated
With a jack, and a board under the pan of the automatic transmission.
Jack it high enough so you can get a socket on the Bolt.
You may have to remove the bolt on the right side mount so it pivots.
For those that don't know
Briano1234 said
Well, You have to remove the bolt on the left tranny mount so that your mount can move.
Thank you Brian
