Wipers not sitting in off location
(In Topic #221237)
I have an issue that I have only recently noticed. When my windscreen wipers are set to off, they sit partially off the bottom of the windscreen at an angle of around 20 degrees.
When I have the wipers switched on, they go right to the bottom of the windscreen and sit horizontally, I assume this is the location they should be in when they are switched off!!
Is there a way to resolve this?
Any input is much appreciated.
Scott
Scott
Ha. Mine do the same. A rapid slight flick of the stalk drops them down but is is annoying.
I’m living with it until I eventually buy a mk2 golf motor and add swap it over.
You need to undo the nut on the wiper motor spindle and pull off the metal arm which moves the wiper mechanism, move the wipers to the park position then re-attach the metal arm to the motor.
Pull the wiper arms up off the screen incase some thing goes wrong and use the wipers a few times to check where they go and park then try it with the wiper arms on the screen.
Here is the usual parked position.
Remove the nut under the cap, the cap comes off with a flat blade Screw driver. Don't forget the cupped spring washer.
Remove the Arm off the Stalk.
Take a 4X4 square piece of Cardboard and cut a hole in the middle of the piece, and place it over the wiper stalk.
Using a small Brass Brush clean the corrosion off the wiper stalk so you can expose the tiny finger bites.
Replace the arm and position it where you want it.
Replace the nut on the stalk, and be sure that you have the cupped spring washer under it tighten it. When the arm can't move your nut is tight enough.
While you have the arm off you can pop off the plastic lower cover and clean it with soap and water, using 3000 grit wet or dry paper, you can sand it semi-shiney. Once you have it cleaned and shiney, use your favorite polish and shine it right up… your arms will look amazing.
Last edit: by Briano1234
Thank you very much for your comments - will look into this!
Thanks again!
Thanks again!
In the 1st thread Thirtleshead said they wipe the full screen when on and only park in the wrong place, the problem with re-moving the wiper arms and re-positioning them is they might go off the bottom of the screen when on so that is why you need to set the park position on the wiper motor so they sit right.
My post was an addition to what you need to look at not that they wouldn't park but why the do what they do.mark1gls said
Yes when you have the arms off you should cycle the switch so the mech parks, then replace the arm,,,but before you "park them" make sure the stalks are clean as they move because the Shaft can no longer bite on the arms correctly, or that the nut loosens usually because the cupped spring washer (actually called a Belleville Washer) under the nut isn't there.
As Briano1234 said they do wipe the full screen and go to the bottom of the windscreen when they are on! It's only an issue when the wipers arw switched off.
Pic when off.
Pic when off.
