Which thermostat
(In Topic #217507)
1991 Mk1 Golf GTi Rivage 1.8cc
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
180 can be used but then the cars heater won't work as good.
Drill a Burp hole in the lip of the new t-stat to eliminate air bubbles while filling, 1/8th or 1/16.
I would also suggest that you flush and back flush your system as well as long as you have a new t-stat, be sure to buy the t-stat cover and new o-ring.
What is the 195 a reference to?
None of the stats on eurocar parts look like yours 😂🤔
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
golf_cab_gti said
Hi thanks bri.
Well on this side of the car the t-stats are rated by temperature that they open at in fahrenheit as well as part number…. so you can ask for a lower opening t-stat for desert places, or in the deep south where in the summer it can get 140+F on the asphalt.
Coolant, 5l is plenty for a change. you need to change this stuff every couple of years, it's ready mixed so you know it's the right strength.
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-accessories/engine-oils-and-car-fluids/antifreeze-and-screenwash/blue-antifreeze/?523770501&0&cc5_865
You will probably have the plastic flange on the water pump which the thermostat is housed in they plastic and can distort and get brittle so you may be better of buying a new flange to fit as well.
https://www.ebay.co.uk/itm/VW-GOLF-Mk1-Mk2-Coolant-Flange-Pipe-74-to-93-Water-FirstLine-055121121F-New/232562107298?fits=Model%3AGolf&epid=2205279858&hash=item3625c823a2:g:-HIAAOSwz~paCzx9
I'm just trying to do as many jobs as conceivable for me to do to keep those mechanic costs down.
I already have that coolant mark thanks. I can't really flush the system properly as the car is cutting out tho so till that is sorted all I can do is prep the coolant system
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
Make sure your heater is set to hot before doing anything, remove bottom radiator hose to drain radiator then remove the thermostat and change it, refit thermostat housing and re fit bottom radiator hose, remove the top radiator hose from the engine/head end and fill up the radiator to near the top or just coming out of the hose, refit top hose then remove the top hose from the radiator end and pour coolant into the engine/head till it's just coming out of the hose when you try and refit to the radiator.
Remove coolant filler cap and top up expansion bottle, leave the cap off and start the engine if you can and leave it to tick over to burb out any air locks.
21 years of driving my car as a daily drive and 292,000 miles on the car I've changed most things a few times.. Ask Briano1234 about anything electrical as that's not my strongest subject.
Iv got the old thermo out did not expect the amount of water out I got haha.
Only just realised that water can run freely from expansion tank out of the where the thermo came from. Thought there and be flaps stops etc do I need the engine running for a proper flush or would a hose pipe do the job?
New radiator is already in coolant system pretty much ready to go wen nee thermo arrives just thought u needed engine running to flush it?
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
