Which outer CV joint kit
(In Topic #222330)
I bought a kit and took it to the mechanic to be fitted. I was told that the i needed a 90mm joint not 81mm.
Spoke to VW heritage and they only have 81mm kits; the only difference between them being the size of the driveshaft.
Can someone advise what i do need - thanks!!!
driveshafts are whats known as '100mm' which is the outer diameter of the inner CV joint
after 1984 the housings were modified to accept the larger MK2 golf outer cv joints
