Where does this go?
Does anyone know where this goes? I had a quick look and couldn't find anything where it would attach too, I shed the Haynes manual but couldn't find anything. Im sure its just the return spring for the brake pedal as the pedal is sitting lower than the accelerator, Im just unsure where it sits. Thank's in advance!
hi do not really think it should be
there the return spring is just above
the push rod  clevis pin mate
I'm starting to think the same thing,  the pedal works fine it just sits a few cm lower then the clutch pedal, I wouldn't of even noticed until I removed bits of the interior.
Should I look at replacing the return spring or is the pedal meant to be slightly lower?
That spring has been put there by someone else… not VW.
It's normal for the clutch pedal to sit a little higher.
What's that blue box attached to the accelerator pedal? That's not the normal fitting for the accelerator cable…..
Are you running a different engine?
hi you sussed the blue box yet mate
I'm running twin40s off the 1.8 mk2 engine. The blue box just pulls the cables.
I removed the bolt and spring, thanks guys.
