Wheel hub housing
(In Topic #231141)
All the bearings are the same for both.
the biggest gimmie is that of your new Spring clips are round eared don't use them the Spring clips have flat ears.
joint with total length of138 mm and shorter drive shafts to be fitted.Car is 1990 sportline.what should be inner seal dimension of cv ,most available seem to be 53 mm
of 90 mm ,is this correct? Bare shaft is 433 mm,Steve
