wheel alignment
(In Topic #207358)
The steering wheel needs matching to the correct wheel alignment not the other way around.
Also of its still wearing the badly worn tyres it will never feel right.
2 options if you have adjustable track rods on both ends of the steering wheel (you will be very lucky if you have the original fixed track rod end VW fitted when the car was brand new)
1. take it off again and put it back on straight and leave it.
2. What you should of done before you took the car in but you may be lucky and it's OK is centralize the steering rack, lift both front wheels off the floor, count the turns from center to each full lock then fit the steering wheel back on so it's in the middle. I think mine is 2 1/4 each way but don't quote me on that.
You may find if you remove the steering wheel and put it on straight it's in the middle anyway.
I'm surprised the garage did not mention this when you booked it in?
If you don't mine me asking how much did they charge for the camber and tracking adjustment?
If you can, count the turns from straight ahead to full lock each way, if a big difference you can just re set the tracking so you have the same amount of turns each way, it won't make any difference to the camber.
Price sounds about right for a full set up, I paid about that and the garage I took mine to mentioned the centralizing of the steering rack before I took it to them as I had took it all apart during the restoration.
