What sparkplugs
(In Topic #236507)
daft question ?
Is there a differance in plugs gti to carb .
I have just swopped to a carb as my injection was naff I have no air leaks it starts fine pulls well idles great at 800-900 the pro len is when I pull away from start the car has a flat spot if my revs are lower than 2500ish the car almost stalls even happens in 2nd when crawling in traffic . I have 4 pin plugs in as that's what I was given when it was gti . Could this be a problem
It is a 1.8 and set to 18 dbtdc is this correct . BUT if I have the choke half on there is no flat spot….Thankyou for any help .
Last edit: by Jigger1970
What carb are you running?
What fuel are you using as that affects the engine timing.
The car drives and runs perfect apart from pull away . ?
What have you done regarding the fuel pump?
As for the fuel I took the intank pump out and the pump next to the tank blew the lines clear put a filter in the tank feed and fitted a bolt on mechanical one with a inline filter b4 the pump .
