Water leak
(In Topic #217423)
Water leak
Water leak
Make sure the new flange comes with a rubber O ring, give the face of the head a good clean and make sure it's nice and smooth before fitting the new flange.
Don't go mad tighten up the nuts/bolts as there is a metal insert in the flange to stop you crushing it, your more likely strip the thread in the head.
Depending on what coolant you are using and how old it is good time for a coolant change?
Water leak
There are 2 ways to go about this, buy two and carry one in your boot.
They only take 87 in/lbs of torgue on the flanges.
to hold them to the block, no more no less, no magic torque elbow.
I went so far as to use a bead of RTV between the o-ring and the outer flange area to no avail, they would eventually fail.
Some "Chinese" plastic is worse than others and it is a
carpshoot as to which type that you get. I did find that there was a supplier over here ALTRON that imported ones in from Ireland, and they seemed (or was it my Irish Distraction) to last a tad longer than the "Chinese Versions".
It is engine vibration, heat and coolant flow that weakens them, the one on the transmission side of the head usually distorts or ovals, and the t-stat warps.
The Digifants just flat out break, lets face it, it was engineering re-work by bean counting. The Bean Counters should be hung by their nether regions, with wire, fed a laxative, then handed a dull serrated knife, as they don't need to reproduce, and should feel our pain.
My 81 Diesel Golf/Rabbit had all metal flanges, and they never failed. Because the metal ones caused the rubber hoses to take the vibration load and not the plastic ones that took the load for the hoses. Face it under engine vibration, heat, and torque which is going to fail quicker plastic that becomes brittle, or the rubber hose.
What I did was scour the Breakers over here for my Digi's to find older Diesel Rabbits, and remove the T-stat, and rear water flanges, I was smart enough to get 4 of each. The one that stumped me was the Digi CTS/Temp sender, but talking with a few folks I found that the 16V CTS sender and oil temp single pin was a direct swap, so I could substitute the 16V non-oil cooler metal flange. Then German Auto Parts over here started to sell re-makes or the end run of the metal t-stat flanges, and I quickly bought two of those, when I mentioned it in the forum on the Vortex, they sold out in a month. Sure they were pricey, 25 bucks each, but I have piece of mind, and metal flanges that won't break.
So here I link the why I hate plastic parts thread, and what I did on my Digi's to get around then breaking, warping and generally causing me Grief in the middle of the night or 50 miles from home.
I still hate plastic parts, but thanks Tolusina. | VW Vortex - Volkswagen Forum
