Warm air intake pipe.
(In Topic #210870)
There is a take off between the 3rd and 4thd cylinder exhaust where it connects usually with a hose clamp or Stainless Steel Wire-tie. then over to the Airbox.
I took mine off when I changed the manifold and then proceeded to remove the Vacuum line that the Pre-heat on the air box used….
Most of us on this side of the pond removes it, I live in the southern US, and it doesn't really get that cold.
carb engines can suffer from carb icing without the warm air system so ideally you want to keep it
