Electrical connection on distributor vacuum hose
(In Topic #240688)
Next on my list is the famous wur valve and check system pressure from fuel pump.
Once the engine is warm you can disconnect and plug the vac advnace hose and you should hear a diiference in the running of the engine. If there is no difference it could suggest a faulty vac advance canister.
Ideally you want a timing light to set up the ignition timing, this is set with the vac hose disconnected and plugged.
paceman said
That is a vacuum operated switch that controls the 'gear change' indicator that will be middle top of your instrument cluster. It plays no part in the running of the engine. I don't know what the internal constuction of it is, but I imagine there is a diaphragm in there that could leak which would stop the vacuum advance from operating as it should. You could try removing it and connecting the pipe direct to the vac advance canister on the distributor.
Hello, and thank you for the info, my car does not have a operational light in the dash anyway so I will try to disconnect it. I have checked the timing advance yesterday by sucking on the hose for the distributor and the internal mechanism moves in the distributor so the diaphragm is working correctly it seems. After setting the ignition to center of the distributor axle to the small groove in the distributor body it was running awful, loads of backfire due to low ignition. I have turned towards more advance and it runs better but need to retard a little more as I hear detonation while on load. my hunt continues
cedar said
Doing what you are with the timing was the old way of setting it, find a hill that the car has to labour up in third and adjust the timing so you get very very slight detonation, but as paceman says use a timing light, it's the only way.
Hello, I agree, but when not having timing light availible i had to "old school" it. I will check it tonight. Old man, old car here
