Injectors are they any good
(In Topic #240379)
Sent from my AC2003 using Tapatalk
Greenmk1 said
Some of the injectors that I have seen have a hat on the bottom, are these hats on the injectors removable or not.
Wrong injectors, yours should be digifant. No Hats, just 2 o-rings.
To clean them I used a 9v DC battery to Pick the solenoid, and Sprayed Berryman's through them. Only took about 5 seconds per injector.
CIS Injector Cleaning, Seal and Holder Replacement
Re: Injectors are they any good
Greenmk1 said
Thanks for that Briano1234 is there a way I can upload videos so just to make sure I am not doing anything I don't need to, knowing my luck they would break whilst putting the metal hats on as I have taken a video of the injectors spraying
Did you look at the link I posted.
Before Berrymans cleanning.
After a few goes with Berryman's.
He also shows you how to replace the tophats on the end.
Also try another injector and see if it works. Are you sure that you have it fully inserted and seated?
