Replacement wishbones
(In Topic #240030)
I've noticed one of my front wishbones appears bent, either its clouted something or a previous owner has jacked the car up under it.
Figured I might as well get a new replacement with new bushes, fixings & balljoint etc, the Febi ones seem a good price but I've read one or two comments saying the quality of them isn't great. Is there a better quality alternative, or are the Febi ones good enough?
Thanks.
The paint finish was not brilliant on the new wishbones so I did touch up some of the chips and thin paint on the edges just to keep the rust at bay.
I know some have welded the new wishbones to make them stronger but I think it's not worth doing as if I do hit a kerb etc I would much rather the wishbone bend then the frame of the car.
If you don't have one I would recommend fitting a lower strut brace while everything is apart, it makes a massive difference to the handling and my reduced under steer.
They come in red as well.
https://www.ebay.co.uk/itm/162741613367?hash=item25e427f337:g:95UAAOSwOn1ahxI4&amdata=enc%3AAQAIAAAA8OViDKfrcoVgUGmJO%2Fmc5CqUMgmd5XpdeyCq%2BwPkg26baCK7MTF%2Fpr0djs5dhGnRYwf9adayY9RybsHdVaSHVW%2B5i94Fx78IpGB6R2aLRmXmBrF%2B4%2F5on%2F2yO7ZXZFdOVIDbcnEVRHAbGHJ3KSrVBsLvKEA3qXraG8rUiteEaprY1BctfCClxvY%2BUjTxNKbvPeQfeZMkgQdl1CnFWyVyz4zmGc8dhYlaswf8I3V0EmQzCTiGiirX6QzSTtf6cQAs5OQvQYVcJyEk1voM%2FKeYTYEOmGA12AGwasiWL4a1ZU2va9JBQBOrYdMO5cve%2BYnqrg%3D%3D%7Ctkp%3ABFBM0oSd7qhi
The strut brace looks good, does it fit onto existing mounts? Any reduction in ground clearance or is it tucked up out of the way?
Thanks.
No clearance problems if you have a manual gearbox and standard engine.
I also brought a plastic cap from eBay to cover the end of the strut brace, sprayed in some waxoyl and fitted a cap.
You can see the bolt here, you do need a deep socket to fit the bolt and only torque the bolt up when it’s on its wheels, I placed my car on some breeze blocks so I could get to the bolt.
I think I might treat her to a strut brace, and if you dont mind I'll nick your idea about the plastic caps too.
I thought the cap would be a good idea as I can just see the end getting stuffed full of mud, water etc as you drive along..
Lower strut brace is the best upgrade to a cabriolet, the later cars new from the factory came with a lower strut brace fitted from new…
