Brake proportional valve
(In Topic #239907)
Cheers Jason
paceman said
What year is the car? On earlier cars (mine is 83) they are residual pressure valves not proportioning valves (that was taken care of by the thing at the back near the rear axle). I replaced mine with aftermarket like you said, think they are the 10lbs ones - should say suitable for drum brakes).
Yeh so mines a 1982 1.6 GTi and it has the bias on the rear axle as well as these valves just under the master cylinder. I wasn't sure the actual name of them I've just seen it mentioned in other posts
paceman said
These are the ones I used https://www.ebay.co.uk/itm/164470776120
Aww great and has there been no issues with these fitted with the rear brakes?
The only issue I had was not tightening the unions up enough. Made a bit of a mess when I was bleeding all my brakes!
paceman said
Nope, none whatsover.
Haha aye brake fluid is awful!
Lastly, obviously these are one way I don't suppose you have any photos of them fitted to yours do you? Just the master cylinder has been stripped so long I can't remember which pipe is which and don't want to put the valves facing the wrong way 😂
Connect it so a front and rear are connected to the front outlet diagonally opposite and then a front and rear connected to the rear outlets for the opposite diagonals.
Obviously you then fit the regulators I. The rear lines only.
I removed mine altogether when I did the disc conversion and once I fix the now pain in the rear fuel pump wiring I shall also be removing the bias valve near the rear beam. Might finally get it back on the road after 2 years.
paceman said
Might sound like a daft question but are the arrows both facing the same way on those valves?
