Cabriolet door seals
Missing trim
IMG_2035.jpg Hi I have recently noticed that when I open either door on my cabriolet it looks like the little part of the door seal has been cut (pictures attached). Short of buying two new complete door seals is there an alternative seal/rubber that I can modify to fit? Thanks IMG_1989.jpg
You could try, but that seal helps to channel the water away from the interior as it hooks to the edge of the door.
That is the only seal that I don't have a picture of.
you after a pair or just one mate
I'm after a pair.
Briano1234 do you mean 171-837-913/F or https://www.werk34.de/en/upper-door-frame-seal-837.171.913-e.html if I cut them down to size?
no cutting to size they are exact fit you have the tails that meet the a pillar missing
So this won't solve the problem?
Is the only solution a full new door seal as the tail will come attached?
Re:
Think I have a couple tipping it down at the moment will have a look tomorrow mate
Sent from my SM-G975F using Tapatalk
No, a tin tops seal isn't the same as the Cabriolet.
Thanks nicci21paul
