Bouncing Speedo (occasionally no movement at all)
(In Topic #239375)
Ive had a quick look at cable connection into gearbox and there is a bit of play up and down if i pull the cable. Should it be tight with no movement at all? Ive not checked behind the dash yet for its connection in to mileometer.
I have had a bit of wiring work done (VDO Gauges, handbrake light, foglight), which could be coincidental but is there any electrical signal to the speedo needle or is it all just mechanical from the cable?
Any help greatly appreciated.
Will also try to tighten up the bracket that holds the cable into gearbox.
Cheers!
As mentioned check instrument cluster end.
No electrical stuff involved with the speedo drive.
This website shows exactly what I'll need to order. Does anyone know the part code for the rubber washer?
?????? ???????? ?? ??????. ????????? ????? ???????? ? ???????? ??????????. ? Volkswagen Golf Mk2, 1,8 ?, 1985 ???? | ?????? ?????? | DRIVE2
NOOOOOOOOO.tnotty said
Thanks very much for the info, I'll take the stereo out and have a look/feel to see if it's dropped out or loose.
Cheers!
The Better way is to remove the drivers side vent. Worm your ARM the rear and re-connect it if it is loose. Going through the Radio if you are not careful will result in breaking a Heater selector mount. You have to remove the 2 screws holding the mount to allow it to float if not your forarm will break the mounting tabs hence my how to repair broken Heater control mounts in the Archive section.
https://www.volkswagenownersclub.com/threads/repair-a-broken-heater-control-mount-cabriolet.52938/?id=52938
Internally broken cables can momentarily cause the cable to catch and stop, then re-spin and bonce between them.
Going through the Side Vent is less bother some.
J
‘81 Golf GTi Mk1 TSR1600 tintop
'90s Chesil Speedster on '70 VW Beetle Chassis
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
New gear fitted, Also replaced the top plastic bracket seal, the small 'O' ring and small snap ring(circlip)that sits in the collar on the cable and hold the gear on. (All of these parts were missing but the speedo had worked fine for the last 10years.!)
Pic for reference (you can just see the small snap ring through hole in the gear)
