what thickness of carpet underlay are folks using?
(In Topic #239222)
carpets
Just looking to put the cabby back together and was thinking of fitting some underlay before I put the carpet back in - thinking of 12mm but wonder if that would be too thick? and maybe not flexible enough?
Has anyone else done this? and what kind of coverage would I need? should i underlay the entire floor? up the sides and up into the footwell too? even under rear seat?
regards
KP
I know when I bought my 81, the difference in pad from the L to LS was 1/2 to 3/4 inch. If you use a Dynamat type of barrier on the metal under that then you get better squeak deadening. I have even seen folks dynamat the inside of doors to stop the tinny sound, but be warned to Dynamat the doors you start at the bottom and work your way up so that no water that bypasses the window seals can migrate under the Dynamat, similar to the way shingles overlap on a roof.
Start at the bottom and work your way up. over lap about 1/4 of an inch.
I have some Dynamat left over from a previous job - I plan to use that for the doors and rear panels ( under rear windows) The carpet underlay was really for a bit of padding to stop the carpet sinking and falling in from the edges. - 3/4 inch seems a lot? I was thinking 12mm was too much
Its quite an old looking green original type material , not really sure how much sound proofing it would give.
https://www.ebay.co.uk/itm/333476511778?hash=item4da4bfc022:g:8fQAAOSw-~teDocI
tnotty said
I used these guys for my underlay, its all pre cut to size/shape. Still not got round to fitting it though so not sure how much it will raise the carpet up..
thanks for that info. I've tried contacting them but struggling to get any response from them on Ebay -
were they pretty good to deal with?
what does the quality feel like? do you know how thick it is? and does it feel quite sturdy?
It's quite lightweight and kind of a 'pan scourer' type material. I'm guessing at 10mm thick but will check tomorrow with more pics.
paceman said
That looks good too. How has it held up? And is it pretty easy to cut?
Btw, Your build Looks amazing!
Thanks for the kind words!
J
