Engine temp is high
(In Topic #238880)
When the pipe burst I did have to drive it home for almost 10 mins.
Any ideas why the engine is overheating? Possibly the sender isn't showing the correct temp?
When the engine is cold remove the expansion tank cap and start the engine, with the engine running (so watch your hands) squeeze the big bottom radiator hose several times then squeeze the top hose serval times, you may see the coolant level drop in the expansion tank. With the cap still removed rev the engine via the throttle cable so you can still watch the expansion tank and see if a jet of water comes out via the thinner hose going in the expansion tank, the flow should increase with the revs.
Put the cap back on and the hoses should start to get hot and pressure build up in the system.
Don't leave it more than about 10 mins running with the cap off or it will over flow.
See if that helps?
If you have the water temp sender on the water outlet, you can loosen it to allow the air to escape as well.
The other way to prevent his from occurring is to replace the t-stat with new, but before replaccing he t-stat drill a small 1/8 inch hole in the lip of it, this totally prevents the Air bubble from hades.
It wouldn't of hurt to flush and back flush your cooling system as well as the heater core after the hose went, as that will flush the scale out of your radiator core allowing it to be more efficient.
