My new thermostat won't open
(In Topic #234952)
What year car and type of coolant system do you have, top fill radiator or expansion tank near the brake servo?
mark1gls said
There is no bleed valve.
I have a 1984 Cabriolet, it's a top fill radiator.
What I do is make sure the car heater is set to hot, undo the top radiator hose at the radiator end, fill the radiator at the cap till coolant comes out the top hose exit. Lift the top hose and pour coolant directly down the hose into the engine till it's full then quickly fit the hose to the radiator, you will probably lose a bit of coolant when fitting it to the radiator.
Leave the cap off and squeeze the bottom hose several times and you should hear coolant moving around and the level in the radiator should also move, add coolant if needed.
Start the car with the cap off, the coolant level may drop a little more, squeeze the bottom hose a few more times to get rid of any air and let the car tick over for a few minutes without the cap on.
Fit the cap and feel the coolant hoses around the engine to check the are getting warm, the bottom hose should be the last hose to get hot.
Keep an eye on the temperature gauge and check you have hot air from the cars heater, wait for the coolant fan to come on and go off then switch the engine off and leave to cool for a few hours or over night then check coolant level.
That is to fill the engine block first with the upper radiator hose attached to the block, then reverse the process to fill the radiator.
Followed by then filling the expansion jug.
Start the car allow the radiator to come up to temp, cycle the radiator fan one time and burp the upper hose.
let cool, then top off the expansion jug.
Regional Host NE
Re:
Never had any problems in the past filling the Cooling fluid just normally start it then fill ittomfooled said
Thanks for the tips guys, I'll try filling the system with these steps and see how it goes.
Sent from my SM-G960F using Tapatalk
