1983/4 Westmoreland GTI Fuel Filter Banjos
(In Topic #233310)
Is the built in check valve important?
I have a 1983 Westmoreland GTI that I am trying to replace the fuel filter on. Everything was swimming along perfectly fine until I managed to shear the out-flow side banjo bolt clean in half. I was using a torque wrench and it never clicked – still unsure how it happened. Maybe I had the wrong torque spec, maybe I'm an idiot, maybe both.
In typical old car fashion, I happened to brake the significantly harder to find banjo. I can't find a replacement but I can find the banjo that goes on the in-flow side of the fuel filter. The seller says it will fit the out-flow side as well but doesn't have the built in check valve.
Will using the banjo without the valve cause issues? Is it something I can get away with while searching for the correct part? Does anyone happen to have the part number for the correct part?
I appreciate your collective wisdom! Sorry if I have posted this in the wrong place as I am new here.
PS: JH code, 1.8L engine
Thanks!
Thanks!
learn the ETKA so you can get the correct part numbers to locate the correct part.
https://volkswagen.7zap.com/en/usa/
