Mk1 Instrument Cluster change
(In Topic #232438)
Can you use slightly different clusters??
Faulty Unit 155 919 035 / 155 919 059 b
Anyone know if a slightly later version would do the job?
this is the faulty unit
Would this work as a replacement? (below)
The connectors are different so you would need the different plugs wired into your dash loom.
The mount points are different too which requires either adding new holes to where the cluster mounts into the dashboard, or moving the pins on the side of the cluster (the ones at bottom left and right of your 2nd picture.)
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Whilst it's possible to fit anything to anything with enough time, £ and effort, to give yourself a fighting chance I'd look continue to for a MK1 part so it's atleast from the same model of car.
What's the fault with the ones from your car?
the_whip said
While it is doable, it's certainly not a straight swap.
Thanks, Noted
Early-1800 said
It's not just slightly later its from a different car (MK1 vs Mk2)
Told the unit has failed and is causing an issue with the battery becoming flat/not holding charge
managed to source the correct unit now
Good luck with the new one.
