Girling 54 problem fitting!!
(In Topic #206280)
So, i just bought girling 54 calipers, brackets, 256 discs etc. The problem is that it has 95mm and my mk1 has 75mm! I have found some g60 brake adapters but they all say 280mm. So can i buy the g60 brake adapters that i can fit the brakes to my spindels and run 256mm discs (because of wheels)
Thanks!
Website Manager
Website Manager
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=modifications-and_2%2Faudi-80-coupe-2-6-v6
I only think that you can get adaptors for 280mm as there is not enough room for 256mm versions.
There is a solution using a Vauxhall setup that requires some shoulder bolts - search this forum or google it as there are loads of folks who have done it.
Jok3la said
Thank you mate, you've been big help! I think i will order the 280mm adapter and put 280discs too. Little bit worried how they are going to clear the wheels but hopefully i can make them work!
Bare in mind that you will then need 280mm carriers AND adaptors to fit 280mm discs…
Would this fit behind a bbs ra 15 mk2 16v type?
However since the 280 calipers are bigger this could give clearance issues even with 256mm pads. But if you keep the audi calipers since they are narrower you'll have to use part worn 256mm pads, and/or grind the slider pins down a bit to get them over the thicker 280mm discs
