Grinding noise on cold start (1.8 GTI DX)
Hi!
I hope you could help me locate this noise, It only happens when starting the car cold after several days, after a few minutes it disappears.  I have tried to turn the engine off and on when it does but when starting it continues to do so.
https://www.dropbox.com/s/hdffb5ncn6f1bhi/65F2781E-CC12-4376-A89E-6B6DD867E457.MP4?dl=0
https://www.dropbox.com/s/uf6sz6qdo4t5m4k/3CF7298B-B049-4AC8-8E00-5EC47280236F.MP4?dl=0
any ideas?
Thanks a lot!!
I think the noise is coming from the ignition distributor.. the longer it is standing, the more noise it makes.  is there anything that can be done?
Never heard anything like that.
Have you tried lightly touching the distributor to see if you can 'feel' the noise if you know what I mean.
Does the noise change as you rev it? Sounds like something catching like a fan on a clipping something, but the fan isn't running so it can't be that…..
You could take the dizzy off and rotate it by hand to see if you can feel anything.
Take the rotor cap off, and reseat the rotor and the cap.
I have had that happen to me out of the blue once.
That is what I did to correct it.
Thanks! i will try that.
i have noticed that it does not do the "cold start" when its cold. The RPM stay at 700 and 950 when warm..
