I keep having to replace my ignition coil!.
No spark and having to replace coils alot
Hi all.
I recently bought a 1986 mk1 rabbit 1.8 carb and I'm having issues with getting it started.
It cranks but not getting spark. Changed the bogey cords and the coil a good few times. Each time everything works but the min the battery gets disconnected  (the car still a work in progress) and reconnected I dont get spark to any of the plugs.
I did have the wiring harness replaced. Is the car maybe not grounded correctly or is the coNections on the coil not connected properly?
Please help.
Last edit: by Seemit
If you haven't replaced your main battery to frame and frame to engine/tranny ground you may want to do so.
As a test, you can take a pair of battery jumper cables and attach one from the negative battery post to frame ground, then the other from the negative battery post to the engine.
