What seems like high revs under hard acceleration
(In Topic #222162)
Baggy19 said
Thanks for the reply's, yeah it does it in every gear under hard acceleration, How do I adjust the clutch? Thanks again
There's a 17mm nut on the cable which can be used to adjust its length, adjust it so there's a little bit of free play in the pedal at the top, eg about 20mm or so.
You don't want it so the pedal is fully up but the clutch isn't fully engaged…..because it will slip.
