'83 Mk1 engine problem
(In Topic #205568)
So, reading the reports and taking advice I opted for a single choke Weber and Mk 1 inlet manifold. now we can get the car to run but the fuel pump is pushing far too much fuel through to the carb. it looks like the original carb had a fuel return to the tank? also looks like the MK2 inlet manifold has a water jacket. the MK1 manifold doesn't have a vacuum connection for the brake servo?
am I correct in thinking that you cant get a twin choke weber replacement for the 1300? seems the logical way would be to used original MK2 manifold and find a replacement carb?
i think your best bet is a later manifold if you have a brake servo, otherwise it'lkl be a bit tricky to stop unless you convert back to the servoless setup…
I do not know if your engine should have the same system or not, but worth checking.
Mine looks like this:
