MK1 steering rack mount
(In Topic #218983)
Steering rack mount
If it still exists (the bracket that is), I have seen and heard of folks that cut the old bracket out, install new studs and re-weld them back on the car, and I have heard of folks that drill through the old studs, then drill through the fire-wall and install new bolts….
They used a large fender washer /neoprene washer on the inside to seal, then a washer/neoprene washer and nut on the outer fire-wall to hold the stud then all bolted up fine. I have also heard of folks drilling through the firewall and welding bolts straight to the firewall.
