advice needed Mk2 16v 256 calipers on mk1 hubs
(In Topic #218599)
if you go for the 280mm adaptors then save yourself a load of hassle, sell those calipers and buy a full 280mm kit. the 256 calipers are narrower and wont fit over 280mm disc and pad combo, unless you fit part worn 256mm pads or grind down the slider pins.
you can fidn 280mm setup off pre-96 mk3 golf gti, 16v and vr6 so not hard or expensive to get.
