1982 1.8 GTI Cab - Exhaust Manifold
(In Topic #204787)
Need to source one!
The 1.8 GTI I want to get running and have as a toy. Sat for 3 years I took the plunge. It came with a few nice extras. I started with a full engine service including cambelt water pump etc. The car came with an upgraded exhaust system or so I thought. As I delve I find a stainless steel manifold held on by a few bolts. The reason being it does quite fit!!!!!!, would need some welding fetteling which I do not have the skills. (Doesn't quite line up to the ports and would be under stress if I did manage to get it to bend into place. The rest of the system is a jetex system, brand new and never fitted, nothing else exhaust wise on the car. So question….I need to get a manifold, I would like the performance part, but don't want to pay through the nose as not sure how good the engine is going to be yet. Please can you advise what exhaust manifold to get and where from, should I go standard…….? Any advice you can give would be greatly appreciated. If anybody has a spare I could borrow to get it running, or if they want to sell, that would be great!
I'll be back with more posts soon, and my GL will be up for sale soon, I have the full service kit, just debating to sell before or after I get it running, it has the most solid shell I have seen on an unmolested car of this age (C reg) Its in blue.
Look forward to hearing from you.
Chairman
Welcome along to the club! I'd say keep them both
As for the exhaust speak to @funkstar or Mark, he runs www.classic-Vw.co.uk should have the bits you need!
Cheers,
Si
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Compulsive buyer of knackered VWs!!!
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
'93 Mk1 Sportline LHD
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
It's best to cover the steering rack UJ rubber boot as the manifold will sit very close to it and it can melt/catch fire! I used a plumbers soldering mat and I also heat wrapped the manifold.sportlinecab said
I've just got one these via eBay for £130 delivered and was pleasantly surprised with the quality. Can't say how well it fitted or sounds yet as its being fitted as I speak! Will update on my project thread soon.
Mine is slightly different to yours.
Last edit: by mark1gls
mark1gls great idea, going to wrap mine too. I guess you have not gone too tight with the solder map so as not to restrict the steering column movement.
Random question, do you know the bolt size for the front water flange? Snapped one on removal. Have managed to get the stud out but need new bolt, I think its M6 15mm standard thread, but if you could confirm that would be awesome, not much luck with google on that.
Just looking at mobile welder to come and fettle manifold as not finding any replacements that will be much better at the mo. Just wanted to get it running, before 'pimping' it too much.
Timmay Zoom Zoom said
sportlinecab : That looks just like the one I have. I think I am missing the second flange part to be able to mount to the next ipe. Do you have this part? Could you chuck up a pic. Mine doesn't quite fit, let me know how you go
Not sure which bit you mean as didn't really look too much at the fittings - is it the stainless steel 'cup' that looks like a beaker without the bottom on it?! If so I got one of those and various other bits I believe. It's being wrapped and shielded accordingly now so hopefully no spontaneous combustion!! Fingers crossed I'll have it back tomorrow but at what cost…….????!!!!😬
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
When I installed the Header on my Cabby, I used sheet aluminum and Metal wire ties, and Hose clamps to hold the sheet metal on.
I also used sheet aluminum to shield the Power steering rack.
I had thought about wrapping, but decided that the shield would allow inspection.
After installing it I had no exhaust leaks, and after about 1.5 years it got rear ended and Totaled, so I don't have a durability report. All I know was it felt like the car got 200 more horses after the install. ok may be 10
£535 for all the work done and £100 of that nearly was extra parts I hadn't bought. Coupled to the bits I had sourced earlier I'm looking at around £900 grand total. Skint but happy. 😀😀😀
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
I'm currently painted rocket and cam covers, from what started off as a service is going way too far!
I’m sourcing a full stainless system with extractors at the moment but after just reading a thread on carby, intake and exhaust manifold maintenance I was under the impression that there are some important components on the standard exhaust mani that sound like I need in situ.
