Mk1 Jetta 1.5 Carb, Starting issues
(In Topic #217837)
Thanks in advance
Have to checked in the the fuel tank or blown down the fuel line from the fuel tank to check for blockages?
You might be able to see if fuel is being sprayed into the inlet from the top of the carb, you can on a Webber carb but I don't know with a Pierburg carb as I've never had to play with one…
If you remove the air filer and cover over the carb can you see down the carb camber and if you move the throttle does petrol spray into the chamber?
Not sure how to move it out of the way as it's been 20 years since I've looked at a Pierburg so check your spark plugs.
I had problems with my original carb and the Pierburg carb is tricky to set up and get running right and it can be hard to find someone who has the "know how" to work on them, I gave up when I had a few problems with my carb and because my car was my daily drive so needed it for work etc I bought a new Webber carb and fitted that, manual choke and easy to adjust/set up, a couple of hours work and I could drive my car without it stalling all the time and only working on full throttle so to get home from work I had to drive flat out then coast along, flat out etc….. Try searching the internet for help on the Peirburg carb.
Can have it for £30 if yours is knackered 👍
