Total lights failure
(In Topic #216732)
Just got a 1989 GTI cabriolet. While driving home the night I collected it the lights just turned off. I held in the stalk and the headlights remained on. But when released no lights at all. So after approximately 1 minute or less all lights would come back on. Very scary at the time. This happened all the way home. Any thoughts what the problem may be??? Perhaps a faulty head/dim/indicator switch?
I hope somebody knows of this problem.
Thank you
It's good to be back in a Golf. I had a 1983 GTI 20 years ago then a '91 16valve.
Grounds are everything….
See my signature.
Load reduction relay as did other things stop as well as possible bad ignition switch.
My rev counter or computer do not work. Just thought I'd mention that Incase it was relevant. I intend to swap out the clocks at some point.
Briano1234 has a great fix for that too
Ian
The answer is yes.
I would check the battery to frame and frame to engine grounds. Check hades, I would just replace them.
Briano1234 has a guide on this and also bulk out the connection to the instruments by adding a couple turns of tape underneath the blue plastic circuit board.
Be very careful when removing the instruments as you don't want to damage any thing and make sure you remove the earth lead from the battery before doing anything so there is no power.
Guide here so you get an idea of what's involed.
How to remove instrument cluster and replace illumination bulbs - The Mk1 Golf Owners Club
