Need Advice / Help buying my first Mk1
(In Topic #203421)
I have done some research on it and beleive it is a 1983 gli 1.8 diesel cabriolet, and I wanted to ask and find out what it actually is and what sort of price it would be worth (as i was going to offer the owner £50 to take it away)
Any advice or words are helpful,
On the drive
Myvalver 89 GTi Grey mk2 16v
The GLi should have a fuel injection petrol engine in it.
How do you know it has a Diesel engine in it, have you lifted the bonnet?
There is a buyers guide on the home page with things to look for, I prefer the cabriolet to a tin top as VW got better at rust proofing there cars from the 80s onwards as early tin tops happy rust away after 10 years on the road.
Tin tops do fetch more money than cabriolets as there's lots of cabriolet still out there.
If you are going to pay someone to restore this car and hoping to make lots of money when you sell it just after its restored then don't as it won't happen.
Are you going to do some or all the work your self or send it away for someone else to do?
Last edit: by mark1gls
Ok thanks ill check it out, and i'm not too fussed on keeping its value, its more for pleasure
Old no turbo VW Diesel engine are noisey and slow but are ecomical to run and are reliable, a original fuel injection petrol engine will be a lot more fun!
I used to own a 1981 tintop 1.5 diesel when I was a student but I much prefer my 1988 Gti cabriolet and both cars are used as daily drives.
If the car has not run in 10 years don't try and start it as the petrol/diesel would of gone off and maybe turned to a sludge and it will damage more parts if dragged through the injection system. Fuel tank will need checking there is an inspection hole under the back seat if you remove the cover and the fuel guage sender you can see into the fuel tank and assess if the tank needs removing and clean out /replace, new fuel tanks £100 ish.
On the drive
Fuel filler neck is a common rust issue as its metal and lives under the wheel arch, take the filler cap off and shine a torch down it. Cabriolet filler necks are different to tin top filler neck, new cabriolet filler neck silly money at £80 compared to tin tops ones at £25.
Cars also seem to rust more at the back than the front and if you can look underneath where the rear beam is fixed to the car (just in front of the rear wheels) and if it's very rusty and full of holes this can be fiddly and expensive to repair.
May be look at other peoples restoration threads to see where there cars have rusted away then it gives you an idea on where to look. Tin top and cabriolet have very simular floor pans.
Let us know how you get on.
Diesel engines have a Injection pump grille side and to the left of the engine with 4 injector lines straight to the grille side of the block and no Distributor.
Gassers have Braided Steel Injector lines off the right of the engine going into a black boot on the right behind battery.
all you ever wanted to know about Cabriolets www.cabby-info.com
I too didn't think any cabbies had diesels….but Euro is different and I think there may have been.
I speak Diesel. Owned a Rabbit Diesel LS for 20yr.
I speak Cabbie's and Digifant.
But it would defeat the object of driving around little country lanes with a truck motor rattling it's head off inches from you and the top down.
One quick way to check is to take the fuel cap off and have a whiff!
