Unknown connectors
(In Topic #217877)
1988 clipper wiring connections
Does anyone know what these connections are for? They run behind the carb, along the firewall and then disappear
I cant find the other end of the connections anywhere in the engine bay!
As long as the connections arent for anything important then i'll leave them in place
That clutch cable seems to be routed the wrong way or the wrong cable fitted as it's got a sharp angle on it and it looks like the cable casing is splitting because of the angle… looks like someone has repaired the bulk head at some point as you can see the welds, may be worth fitting stick on plate as well as common problem for the cable to pull through the bulk head.
https://www.ebay.co.uk/itm/VW-GOLF-MK-1-GTI-BULKHEAD-REPAIR-PLATE-SCIROCCO/272450886331?hash=item3f6f569abb:m:mDc5R0ft1sV4OxxE5dQXBTg
My cable goes infront of the engine not behind..
I could be wrong as I've a fuel injection car….
I havent followed the cable yet so i dont know where it leads, it could well be installed incorrectly and does need to go in front of the engine like you say.
Have you got some pictures of the correct layout?
Unknown connectors
