unit that sits on top of a mk2 16v air box / air flow mass meter??
(In Topic #219570)
need a new one
not sure if I have the name right of the part that I need. It is the part that sits on top of the air box. It controls the flow of petrol and has loads of little pipes? does anyone know or have a decent one that they can sell me pls?
Or can anyone advise as to why the damn thing starts, hunts and then wont run when you press the accelerator it dies? strong smell of fuel as well.
Last edit: by kateski
Could also be weak spark.
Leaking fuel injectors if it only does it when cold and is ok ish when hot….
On the 8v cars the thing that controls the flow of petrol to the injectors is call the metering head.
Sorry but can't help with tuning etc as I've not worked on a 16v engine…
have a read before you buy anything:
https://clubgti.com/forums/index.php?threads/how-to-check-repair-and-tune-your-mk2-corrado-1-8-16v.195423/
and its fine to cut the airbox, did this on mine no problem. worst thing that could potentially happen is air filter gets wet, arch liners helps with this and/or you could make a guard to fit underneath
