Tough to start after a week(or two) stood in garage.
(In Topic #222800)
Lots of turning over to start.
The last few months I seem to be having to turn it over multiple(lengthy) times to finally get it to fire. As soon as it fires it's perfect and idles away happily. It then easily starts up after a short drive. The fuel pump is a bit noisy but doesn't seem to cause any starvation issues when driving hard.
It's in a lockup garage that's a bit cold and damp but nothing I would consider a problem. The weathers not been overly cold either. I'd say it's getting harder each time I use it.
Leads, dizzy, rotor are all under a year old.
Just looking for some advice/knowledge if anyone has experienced anything similar.
Cold start valve? WUR?
Any help greatly appreciated.
Battery if not on a trickle charger then it isn't putting out as good as it should as well as how old is it.
Unfortunately no power in the garage for a trickle charger. Thanks
It's fine to restart once I've got it going. It just takes a huge number of long cranks to get it going(10-15+!) which is actually draining the battery.
Fuel pump is very noisy so I'm wondering if there's a blockage causing fuel pressure problems.
Lots to investigate!
Could be low fuel pressure… but I would guess you would have the problem all the time just not when it's left for a few days…
How old are your spark plugs as it’s best the change them when replacing the HT leads as you said the leads, dissy and rotor arm are under a year old..
You need to work out if your problem is electrical or fuel and go from there, try cheap/free checks/fixes 1st before throwing money at the fuel injection system as things start to get expensive and a fuel pressure gauge is best for fault finding the injection system.
Coil was a cheap part so may be an issue.
Hopefully have a good old look at the weekend and try to eliminate a few possibles
But then put the connections back onto the old coil and it started perfectly. I've still put the new one on (only a cheap topran brand). And am assuming it's a damp issue causing the problems. Have sprayed a bit of wd40 over the connections and will keep the spare coil on the car so it stays dry.
Would a more expensive(Bosch) coil be less susceptible to damp?
Easy fix if this is all it proves to be.
Thanks for everyone's input.
Spray them with CRC wire-dri.
Close them, then over spray them with Krylon Clear to seal them, or coat with plasti-dip….
Learned that little trick on my 67MG, and I could go trough some puddles with no chance of electrical stalling, also spray the HV leads as well as the inside of the dizzy.
you could also wrap a bit of insulation tape or vulcanising tape around the joins to try keep moisture out.
On the drive
Myvalver 89 GTi Grey mk2 16v
Considering making up a cylindrical rubber boot to cover over the end and connections.
But For now a bit of wd40 should do the trick.
