Torque settings for sump bolts - Mk1 Campaign
Hi guys,
Going to put a new sump on this weekend.
Have the sump and a rubber gasket.
Haynes manual (the Brown manual) says:
Socket head torque = 5 lb/ft or 8Nm
Hexagon head torque = 14 lb/ft or 20Nm
I have typical bolts == Hexagon head so that means 20Nm.
However did search on here and someone recommended 87 lb/in which equates to 10Nm.
Want to get this right as over/under tightening can cause leaks or damage.
Any thoughts?
Dave
Hi
Bolts are M6 with hexagon head.
8 Nm is more than enough.
And torque the bolts gradually and in a crosswise sequence.
20 Nm is used for M8 bolts.
Greetings Kris
Always done 7-8nm here.
20nm, Fugeddaboutit…
Thanks guys - 20Nm did seem a bit strong given there are about 20 bolts.
Will go with the 8Nm.
Cheers!
Just to add - with a rubber gasket - not going to use any sealant - heard horror stories of sealant getting into oil ways and pump!
Any views on sealant?
I replaced the sump on my caddy and also put I rubber gasket in with no sealant. No probs here yet as I also read about possible problems
Always used a thin smear myself.
