too much pressure at expansion tank ?
(In Topic #210696)
If you have a black cap change it for a blue one as black ones are more prone to failure.
I was afraid that head gasket might be failing, but the symptoms dont really fix to that kind of problem ?
Last edit: by Petrif91
Parts needed
2 Latex gloves, Big Lipped Balloons, or Condoms.
Cold engine.
Remove expansion tank cap.
Tie the Glove over the opening tightly.
Start the car, and from under the hood REV the engine to 3000 RPM for 30-45 seconds, if the Glove or condom inflates and gives you the finger… Bad Head Gasket, or Oil Cooler.
I personally don't like the Water filled Oil Coolers as they can intermix. Usually you don't get a/f in the oil, but you get oil and pressure upto 4.5 bars injected in to the cooling system.. Ballooning the hose, and things.
If I had an Original Oil cooler on my car, I would replace it first, and retest to eliminate it as being the issue as head gaskets are a wee bit more costly, and what if you replaced the head gasket, and the cooler was the issue to begine with.
Also exhaust manifold is cracked
I'm pleased with the results I got fitting mine, the engine is pulling much better above 4,500 rpm and the standard exhaust I still have even sounds much better.
I did wrap mine to keep the heat down in the engine bay, I also covered my rubber UJ joint with a plumbers soldering mat to stop the gater melting.
