throttle valve idle adjusting screw
(In Topic #231980)
base setting from a rebuild
1. use a new o-ring.
2. Wrap the Idle By-pass Screw with 2 wraps of Teflon Tape, the threads only, as when the o-ring goes, it will still be unable to pass air and screw with your idle.
I usually bottom the screw out then 1 1/2 full turns out as a start.
Just need the weather to improve a little to see if the throttle screw setting came good.
