Tapered or radius wheel bolts on bbs
(In Topic #226364)
I’m not sure which to order, the wheels are bbs, no mention of vw or bmw just bbs on the wheels themselves.
I just did a quick google search and found bmw use tapered whilst I know vw use radiused ….
Any ideas guys?
Another 'test' is to place a bolt from the steels through the holes and pull on the thread side of the bolt. Give it a wiggle. If it moves a lot then it's probably not the correct bolt head type.
TBH in MOST cases alloys have tapered head bolts not radius bolts. But that's a rule of thumb. Radius bolts TEND to be used on steels only.
I've used this chap in the past
Home
You'll have to phone him to have a chat about bolts though
Ian
So I had a closer look. I puffed a light spray of paint on a radius bolt, stuck it in the wheel and turned it, then looked at the marks left.
Did the same with a tapered boot.
I came to the conclusion that the wheels are designed for radius bolts. Also the tapered bolt is wiggly in the hole whereas the radius bolt seems more snug.
The radius bolt only seems to catch in a single place whereas the tapered seems to have caught all across it's surface.
Does the surface in the hole feel dished or flat?
Might be worth popping in to a tyre place that sells wheels and get their advice.
Ian
Steve1973 said
Shove a ball of blue tack down the hole. Take it out and see what shape it is. Might work, give it a go.
I'm thinking I might go and source some bluetack!,
